Durangos are known for crank sensors to go bad. Make sure that your battery is fully charged so you know that isn't an issue. If you don't have the proper equipment, try this.. Your going to need someone else's help for this. Pull one of the spark plug wires, using a screwdriver, put the tip of the screwdriver into the wire and hold the shaft of the screwdriver about a quarter inch away from a good ground source. Have your assistant turn the key and crank the engine while you check to see if you have spark. If you can, visit your local parts store and ask for a noid light that will fit your vehicle. It's usually about $10-$12. The purpose of the noid light is to check for injector pulse. Disconnect the plug for the injector and connect the noid light in it's place. Once again, crank the engine and check to see if the noid light lights up and pulses. If the crank sensor is bad, you should have no spark and no injector pulse. Replace crank sensor if so. If you have spark, check for fuel and or fuel pressure. Listen for the fuel pump to energize when the key is turned. Also try spraying starting fluid into the throttle body. If it starts, your having fuel issues. I hope these tips help. Good luck.
SOURCE: 1998 dodge neon turns over but wont start
your crank sensor it is located on the back of your engine block behind the alternator check it see if it is bad
SOURCE: 2000 Dodge Ram 1500 (V8 5.2L) will not start
could be the battery, sometimes all the electrical would stay on but the battery doesnt have enough juice to crank the car over, if not check the alternater.
SOURCE: my 2004 dodge durango is leaking oil what should I
Hurry back !! Tell them right away.. Tell them you did not see this the day you got it.. Tell them you want it fixed right away..
In some states you can return the car within 3 days..
Check what your state laws are on auto purchas..
SOURCE: Dodge Neon engine turns over, battery fine but car doesn't start
the timing might have jumped a tooth. hope this helps.
