Model # TL-WA854RE
SOURCE: Password Problems
Maybe you are getting LIMITED OR NO CONNECTIVITY. This happens when the wireless adapter is able to find a network but the pc cannot get an ip address. One of the reason for that is that your wireless network might be secured and you missed to enter the correct network key when you were asked by the computer. The wireless security is set on the wireless router, SO WHEN YOU SET THE PROFILE ON YOUR WIRELESS ADAPTER, YOU SHOULD ALREADY HAVE THE WIRELESS SETTINGS FROM YOUR WIRELESS ROUTER. THEY HAVE TO MATCH FOR YOU TO HAVE A COMPLETE CONNECTION.
SOURCE: how protect my DNA-A211-I wi fi
Go to START and find RUN, then type in CMD and hit ENTER, should throw up a black box (Dos window) you will type IPCONFIG and it should give you an adapter gateway ip address like 192.168.0.1 or something like that, from there close out that box and launch internet explorer or firefox or netscape or whatever browser you use. Type in the ip address where you would normally type www.google.com. Hit ENTER, this will interface you with the router. It might be password protected. Usually the username and password are both the word admin. If not look at the bottom of router for password. Look for wireless tab once in router and select network type as wep. Look for the key that the router automatically generates. This will be your wep key. Now your wireless connection will be secure. Hope this helps...Tennis123
SOURCE: login to router
Leave the username blank, then enter "admin" as the password. You can also reset the router to factory defaults by pressing the reset button on the back (small hole, use paper clip) and then try again.
SOURCE: My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
