Question about Cisco Linksys Wirelessn Router Black (e1000)
Ipod wi fi conection - Cisco Linksys Wirelessn Router Black (e1000)
Posted by dfdawnmarie on
P C
    Sniper:
  • 62 Answers
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (ipod wi fi conection - 307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ipod wi fi conection - 307189_1.jpguploads/images/307189_1.jpg" alt="307189_1.jpg" class="h_mi" />).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wipod wi fi conection - 307189_3.jpg the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi nipod wi fi conection - 307189_3.jpg>Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Posted on Dec 27, 2010
1 Related Answer
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
Itouch problem with internet conection
Go to Settings and then click on Wi-Fi select your network and then put in your password and you will be able to connect. Hope this helps.
Dec 25, 2009 | Apple iPod touch
I cant get internet on my ipod touch when i am conected to wi-fy
This error means you're not connected to an internet-enabled network. If you want to surf the internet, you'll need to connect to a wireless network; you do that by going into Settings, then Wi-Fi.
If the WiFi option is off, press it to turn it on and it'll scan for near by networks. Once you find one that is unprotected, or one to which you know the password, you can connect to it by pressing its name. Once you connect, if that network allows for internet access, you can surf.
If you don't have any wireless networks within range, you can always set one up yourself. You can do it either with a wireless router, which will give you a permanent access point you can use whenever you feel like, or using a laptop - but that's difficult, not permanent, and has a very short signal range (Though it's free if you already have a laptop with a wi-fi card).
Aug 07, 2009 | Apple iPod touch
Tip
How do I Get Wi-Fi on my iPod Touch if it Says No Wi-Fi
<p>One of the most useful features of the iPod Touch is the ability to use the Internet through a WiFi connection if you have a wireless home network and within range of your router, you can access the Internet via your iPod with ease. If you're in public, you can use the free wireless internet businesses such as hotels, cafes and airports. If you are not in a Wi-Fi zone, will warn you that your iPod will not be able to get online. When this happens, then you need to move to an area that has Wi-Fi <br /> <p><br /> <p>1. Confirm your wireless connection is configured correctly by checking if you can get online on your home computer. If your router is not configured correctly, you will not be able to use their access to Wi-Fi with your iPod. <br /> <p>2. Go to a place where you know Wi-Fi is available. In urban areas, Wi-Fi is available in many businesses and families. Press the "Settings" icon on your iPod, click on "Wi-Fi" to search for available networks in the area. If there are none that appear, confirming the Wi-Fi icon at the top of the page is set to "On" instead of "Off". If no network can see, you're in an area where there is Wi-Fi available. <br /> <p><br /> <p>3. Click the name of an available Wi-Fi network and enter the correct password. Sometimes you may not be able to access the network, because you do not have the password. While companies such as pubs and hotels to their networks without protection for the enjoyment of their patrons are usually password protected networks. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How to manually enable Wi-Fi on an iPod Touch
<p>IPod touch not only offers a music library on the road. It also has Internet capabilities. The iPod touch can connect to wireless internet connection available and browse the web using the Safari browser included on the device. Typically, Wi-Fi capabilities automatically. But if your iPod touch wi-fi is off, or if you activate it, you can do it using the Settings window. <br /> <p><br /> <p>1. Touch the "Settings" icon on the main screen of the iPod touch. <br /> <p><br /> <p>2. Touch the option marked "Wi-Fi." <br /> <p><br /> <p>3. Touch the "On" next to the setting marked "Wi-Fi." <br /> <p><br /> <p>4. Tap a wireless network list to connect. <br />
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Tip
How to install a Wi-Fi in iPod Touch
<p>The iPod Touch is a portable media player, game console and personal information manager developed by Apple. The first generation iPod Touch was released in 2007, the fourth current generation was launched in 2010 at the time of publication. Among other hardware features, the factory setting of the iPod touch already has a wireless adapter 802.11b/g/n standards for all. The operating system runs on the iPod touch is set at the factory to take full advantage of this hardware. You can sign up for free Wi-Fi with iPod touch. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." Push the "Wi-Fi" control "ON". <br /> <p><br /> <p>2. Push the "Request for new connection" control "ON". <br /> <p><br /> <p>3. Enter the radio band - usually at least 100 meters - the Wi-Fi is connecting. IPod touch displays a message asking if your network that detects the radio signal to connect. Answer "Yes". After a few seconds, you will see the Wi-Fi icon in the status bar of the iPod touch; iPod touch will be ready for the wireless network connection. <br />
Tip
How do I delete the Wi-Fi from my iPod?
<p>IPod is a line of various models of media players made by Apple. The flagship of this line, the iPod Touch, includes the ability to connect to computer networks wireless 802.11b/g/n following international standards. Also, remember the iPod Touch Wi-Fi networks are members in the past, allowing the user to save the trouble of having to re-enter network keys and other authentication tokens. However, sometimes a user may need a specific Wi-Fi memory to remove the iPod Touch - for example, when the network configuration has changed. <br /> <p><br /> <p>1. Play your iPod icon "Settings" and then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that time, the iPod touch loses any memory connected to that network and configuration parameters of the past. <br />
Tip
How to find a wireless password for my iPod Touch
<p>If you try to access the Internet to your iPod Touch, Wi-Fi hotspot and only that will detect the device is marked with a padlock, which means you need a password to use Join the network type. Ipod touch internet access via Wi-Fi, allowing you to browse websites with the Safari application, check your e-mail and free video calls with Face Time app. You need someone for the password if you want a Wi-Fi closed. <br /> <p><br /> <p>1. Ask your department manager of the company computer network password for the Wi-Fi when you use your iPod Touch to access the Internet while at work. <br /> <p><br /> <p>2. Check the password for a printed receipt to a Wi-Fi closed after making a purchase of a restaurant that offers Wi-Fi service to paying customers. <br /> <p><br /> <p>3. Ask your neighbor for permission to your WiFi signal, if you want to access the Internet via Wi-Fi network from your computer. If you are on friendly terms, she would give him the password. <br /> <p><br /> <p>4. Go to decree or in a mall and ask for the password to block Wi-Fi, so you can access the Internet while you shop. <br />
on Jul 21, 2011 | Computers & Internet
Tip
How can I permanently delete a Wi-Fi from iPod?
<p>Include network interface, the iPod Touch is equipped with a wireless adapter that allows hardware to join Wi-Fi networks by default, an iPod Touch love all Wi-Fi was never confirmed, this feature saves users the reenter the work of key network authentication and other parameters. However, in some cases, a user can have a Wi-Fi network to remove the memory of the iPod touch - for example, when the network configuration has changed. You can also prevent applications such as Safari Internet access. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that moment, the iPod Touch lost all memory you have connected to that network - past and configuration parameters. <br />
Cisco Linksys Wirelessn Router  Black (e1000) Logo
1,361 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
