Acer AOA150-1690 Aspire Notebook Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aspire 1690 - Backlight on screen is failing Rose
Aspire 1690 - Backlight on screen is failing Rose color on left side of screen. Where can I get this repaired in Boise, Idaho?
Anonymous
Level 3:
  • Acer Master 32,281 Answers
  • Posted on Jul 08, 2009
Anonymous
Acer Master
Level 3:
Answers
32281
Questions
Helped
7913354
Points
102259
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Where is the WLAN switch on the Acer EXTENSA 52325
i Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
I get an intermittent shadow on the left-side of myscreen. Computer works fine, except at times I have the shadow.
If you mean that the left side of the screen goes darker than the right side, then this is an indication of a faulty backlight. There are probably two CCFL tubes, one on each side of the screen. If one starts to fail, then that side of the screen will get less light and look darker. The tube may need to be replaced.
ACER ASPIRE HAS NO DISPLAY
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Screen Problem
In most cases where you start getting a pinkish tone or red tones....the screen is close to failing. It is not the backlight....this is the actual screen itself that is failing. There is no repairing it, it must be replaced.
My netbook won't booting,power ligth on but power ligth remain on
There are approx 6 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Hi, I have recieved a used laptop from a friend.It is an Acer Aspire 1690LCi ZL3. The unit powers on,battery is good,DVD drive opens but the screen is dead.Please help. Sam
A few things to try. First turn on the unit, and after it seems to have booted up (like at a windows login or something), take a flashlight and in a darkened room shine it on the screen. If you can see a picture, it means your backlight is out. Go on ebay or elsewhere online and look for an acer aspire 1690LCi backlight. Then open up your screen and replace it (there should be tutorials online for this). If you don't see an image, your screen maybe be out or have more serious problems (video card, LCD dead, etc.).
Acer aspire1690
Your screen sounds fine, most likely just your backlight going out, either that or you could have hit the key for using an external monitor (function f6 is the LCD/external monitor switch for my computer). I'd look into the function f6 and play around with that, if not you can just buy a new backlight from ebay or an internet supplier.
Aspire 1690
back up your personal info, pictures, docs, all that you need conserve. Format the computer and install english operating system.
Good Luck
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
