Question about Acer Aspire 5100 Notebook
Where is the WLAN switch on the Acer EXTENSA 52325
Posted by nicklaw1 on
Gerald Eugenio
    New Friend:
  • 48 Answers
I Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
Posted on Sep 09, 2011
Acer 4220 extensa cant connect thru WLAN. says no wireless device... how come it has 802.11WLAN.. how come it says no wireless device
It could be that the wireless card in the BIOS setting has been disabled/switched off. Check your BIOS wireless setting.
It could be that the wireless card driver has not been installed.
Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
May 10, 2011 | Acer Extensa 4220-2346 Notebook
Acer extensa 5220 wlan for windows 7
Check out this Link @ http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=714
Select your OS & download your respective Wlan device for your notebook.
Hope it helps
Mar 12, 2011 | Computers & Internet
Network driver issue
Here are the possible drivers:
LAN Driver:
http://global-download.acer.com/GDFiles%5CDriver/Lan/Lan_Broadcom_10.46.0.0_Vistax86.zip?acerid=633639019634312942&Step1=Notebook&Step2=Extensa&Step3=Extensa%204220&OS=V10&LC=en&SC=PA_6
WLAN Drivers:
Atheros:
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Atheros_7.2.0.215_Vistax86.zip?acerid=633639019788127956&Step1=Notebook&Step2=Extensa&Step3=Extensa%204220&OS=V10&LC=en&SC=PA_6
Broadcom:
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Broadcom_4.170.25.19_Vistax86.zip?acerid=633639019791247936&Step1=Notebook&Step2=Extensa&Step3=Extensa%204220&OS=V10&LC=en&SC=PA_6
Intel:
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Intel_11.5.0.34_Vistax86.zip?acerid=633639019799203885&Step1=Notebook&Step2=Extensa&Step3=Extensa%204220&OS=V10&LC=en&SC=PA_6
Jul 11, 2009 | Computers & Internet
WLAN wont work after reformatting
http://support.acer-euro.com/drivers/notebook/ex_4620.html  use this link there two hardware of wlan  intel and broadcom under vista. try them.
let us to know  it works.
May 29, 2009 | Acer Extensa 4620 Notebook
WLAN does not work after reinstalling vista
If by WLAN not work you mean its totaly off then the chip burned out and you should send it ini to your computer maker for repairs. If its not then you should remove and reinstall the latest wifi drivers. (save old ones first) also make sure its not your WLAN Modem
Apr 23, 2009 | Computers & Internet
Downgraded from vista to xp now blue tooth and wlan switch/are/nw
It most likely would of been the utils that you need to install that will run in the background with regards to bluetooth or wireless ( wlan ) which when you installed the drivers for xp should of given you the option to do.
Apr 14, 2009 | Acer Extensa 4620-6402 - Core 2 Duo T5750...
Unable to connect unless hard-wired ethernet cable.
There is a WLAN switch located at the front panel of your laptop. It looks something like this (( /\ ))... you need to switch it on for Wireless to work mate :-)
Feb 20, 2009 | Acer Extensa 5420-5687 Notebook
Find wi-fi on/off switch
if it has WLAN which mostly llaptops have now adays look for Dish antenna like sign on the front panel of laptop it might be somehwere on function keys if u find it just pree it with the FN key it will turn on pls check in ur config on the box or beneath the laptop there should be written somewhere intel 2200 BG or 3945 bg or intel 4965 BG then it has wifi otherwise not there is no need ofr finding it but it should be there if u bought like after 2005
About,wifi/WLAN,ACER EXTENSA
801.11 a/b/g WLAN is wireless networking (wifi) and can be used in a wirless hotspot.
Feb 02, 2009 | Acer Extensa 4620 Notebook
Acer Aspire 5100 Notebook Logo
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
