That crackle is usually a failed high-voltage rectifier diode. It's possible that the magnetron is failing or failed, too, but I would suspect the diode first.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
It's always recommended that you have the hood fan on when cooking on the stove to prevent moisture from entering the controls of the microwave.
Also, I tell my customers to be sure no one ever sprays cleaner directly on the keypad.
But I don't think those are factors in your case.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
