Televison & Video Logo
n
nikki jayne Posted on Jan 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My alba tv will go onto standby when I plug it in but it wont turn on when I try to turn it on with the tv remote
Ive unplugged it and changed sockets tree times changed the batteries twice and changed the fuse and still comes on to standby but wont turn on properly
Level 3:
Top Expert:
  • Alba Master 76,851 Answers
  • Posted on Jan 16, 2015
Alba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008112
Points
237762
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 01, 2009
SOURCE: will not turn on with remote
Read my post on getting a new board for $139.
Anonymous
  • 4 Answers
  • Posted on Jan 03, 2009
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 12, 2010
SOURCE: Polaroid 26inch lcd tvred standby light on but power wont turn on
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jerry Umali
  • 979 Answers
  • Posted on Apr 15, 2010
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Testimonial: "how helpfull thanku kindly !"
Anonymous
  • 293 Answers
  • Posted on Jul 03, 2011
SOURCE: tv will not turn on
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
What's your problem?alba lcd32947hd won't turn on from standby mode
My tv just over a year old Alba LCD32947HD - PSU - 17PW25-4 - 250111 V1 - 23012666 gets no power on and not even a light in front after I plug to the mains. Checked and power goes to the psu , main Av and the Inverter. Can somebody help? Could that be the remote control. Please help. Thank you in advance. Harry.
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
6helpful
3answers
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
2answers
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
2answers
Wont come on
try pressing one of the number keys instead of the power button on the remote
Top Alba Televison & Video Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
