Televison & Video Logo
Question about Alba Televison & Video
Is it possible to enter the service menu on alba aelkdvd1988 portable tv i'm trying to see if i can get the usb port to read a flash drive with movies on
Posted by Jamie Linaker on
francoise cleofas
    Genius:
  • Alba Master
  • 2,432 Answers
You can see in the menu the video support read by the player. also in the front panel of the unit their is a tag what format can accept like divx or mpeg etc.
Posted on Sep 07, 2012
5 Related Answers
Anonymous
SOURCE: i have LCD TV LG
i have the same problem on mine too. the usb icon does not even appear. please someone help!
ASHGRAY.
Posted on Nov 22, 2010
Anonymous
SOURCE: 32LG3000 TV LCD - usb port ''service only''
Yes it's possible to use the USB port , you only have to change settings in TV setup to change it.
With software ver 3.15 it's very easy see link below how to change setup.
http://lgusb.wikispaces.com/#support
Posted on Mar 21, 2010
Anonymous
  • 124 Answers
SOURCE: My lg lcd tv has a usb port but only recognises
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
Posted on Nov 04, 2010
Anonymous
SOURCE: Help Playing .mkv File on Samsung UN55B6000VF
The solution is very easy, format your usb drive to NTFS and go on.... FAT file system have that problem, it not copy big files....
Posted on Aug 03, 2010
Anonymous
  • 3006 Answers
SOURCE: I plug in the USB
First, try using a different USB stick. If that doesn't fix the problem then your new tv is either faulty or the tv operating system has a bug.
Check the LG website in your country to see whether there are any firmware updates available. If not, then return the tv for refund or exchange, but make sure to try your USB drive on any replacement set in store as it's highly likely to be a bug in your model which will affect all of the other examples as well.
Posted on Sep 22, 2010
I have a rca model rtu5540 . I don’t know how to activated the USB on the side of the tv, the book they give...they said it s a service port but give no explication how to activate.
USB flash drives require no power up. USB cameras, etc. may have a power button. If you insert, let's say, a flash drive into the TV's USB port, making sure it is fully inserted, it is already powered by the TV. What you are encountering is not a matter of activation but rather access which is granted by settings of the TV. You basically select from "input" menus, the USB choice. The TV then reads what is on the flash drive. You may have to move through the input options using your remote as such controls may not be otherwise accessible. The "input" menu may be the one that allows choice of HDMI, DVD, etc..
1helpful
19 Inch HD Ready Digital LCD TV/DVD Combi. Is it possible to use the USB port and if so, how?
Dear Megan,
This Port could be a Service Port or USB Input and /or USB Output. Make sure it is Not labeled "service only"
If you have a Jump Drive with pictures / music on it, plug it into the port and see what happens. This port could also be used as a charging port for cellphones,GPS etc...depending on the function it was designed for.
Good Luck!
JP
3helpful
3answers
I have a RCA RLDED3258A-B 32" TV with an usb port "for service" How can I activate this port to play videos from an usb drive
Oh well... my Samsung TV reads directly from a USB stick -- great for watching downloaded movies, no need to burn DVDs, etc.
Portable device tab missing in device manager
What type of portable device? Are you talking about something like an external drive or a usb flash drive or something that you plug into the computer's usb port? If so, maybe the usb port is bad, so try another usb port.
Maybe the portable device is bad, so try using it on another computer and see if it is shown. Most times it will show up under My Computer along with the hard drive. Click Start/My Computer and see if it is shown.
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
1helpful
2answers
Unhide hidden object in my sd card
Insert the USB drive into your computer's USB port and navigate to it through My Computer.
Now double click on the USB drive.
Once in the directory of the USB flash drive click tools at the top menu bar of your screen. Then click folder options. Now click the view tab. Scroll down a bit to the folder heading that reads: Hidden Files and Folders.
Select the option that reads: Show Hidden Files and Folders.
Now click apply and then OK.
This will show all available hidden files and folders that are present on your USB flash drive or card.
Take care!
damnor01
31helpful
2answers
Samsung dvd-d530 doesnt play usb. Please tell me how to reset factory settings or original grid code.
i I have a problem with my samsung dvd D530, it doesn't read the disc or the usb anymore. i cannot even enter the settings,all I get on the tv screen is ''no option''. can anyone tell me how to reset it?until yesterday it worked perfectly fine.
2answers
USB video file wont play
.avi format it supports
5helpful
2answers
Alba servic mode
THE TV JUST GETS A LITTLE BLUE BOX ON THE SCREAM THAT SAYS CAN'T GET SIGNAL
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
