Hi,ive got a sharp aquos model lc-50le751k.it wont turn on,if i plug it in turn on at socket,blue light comes on front panel,nothing else,no sound no picture,if a press a button on remote blue light flashes but still nothing,fitted new power board made no difference ,please help
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
SOURCE: Flashing Green Power Light - No Picture or Sound
try accessing tv through the remote control.
SOURCE: no picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
