Dehumidifier's control By percent room Realative Humidity Or better known as rH% , if your not sure your unit is working or even cycling properly , purchase a seperate rH meter(there not expensive) and place it in same room someplace , Normal %rH for a homes room is 70%rH set your units setting for a target of that number and use the seperate meter to verify thats what it is (takes 24 hrs) , if Meter is consistent Higher or lower a reading that whats set on unit then yes you might have a problem with your unit
