SOURCE: I need to change the switch of a washing machine,
hi there.remove the screws at the rear of the lid,then push the lid backwards,from the front.its held on by pegs that lock into the lid.hope this helps,steve
SOURCE: whirpool washing machine it won't spin after it drains water
Check if there looks like black powder under machine
This would be the coupling falling a part
It is worth fixing and not to hard
The part is under $10
SOURCE: HOW TO INSTALL A BELT
Take the back off and the belt can easily be installed HOWEVER if the tub bearing is shot the belt will not stay on.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: How to replace the timer
watch the FIRST 1 MINUTE 10 SECONDS of this video if will show you how to disassamble the control panel,the rest of the video wont be revelant to replacing the timer but it will help to get into the control panel
First step before opening the control panel is to push in the timer knob and unscrew the knob in a counterclock wise direction and then pull the dial off, a screwdriver can be placed behind the dial to assist in removing it. Under the dial are the screws that hold the timer to control panel
here is that video http://youtu.be/9K1KHEogf3c
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
