How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Brad Brown Jul 18, 2016
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? model number
5 Related Answers
Anonymous
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
Muddley
SOURCE: whirpool Ultimate care II
I have played with the machine at length today... In the hope that if this was merely a blockage, I could move it...
If I go to a spin cycle, the machine begins to work normally, bringing in some water and then spinning slowly... It seems then, that the pump does not engage, thus leaving the water in the drum and not allowing the machine to speed up to a full speed spin.
If I enpty the machine using gravity to drain the water, the spin runs normally.
Obviously draining manually is not viable during a wash cycle. Is it possible that there is a switch for the pump, which is in need of replacement, or is this a requirement to replace the pump.
Posted on Jan 27, 2008
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Posted on May 21, 2008
Anonymous
  • 61 Answers
SOURCE: Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Posted on Dec 23, 2008
robocop
Bill Batross
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
Why won't Whirlpool washing machine spin
Most likely cause, Lid Switch broken
2nd) Broken motor coupling
3rd) Obstruction in water pump
Jul 08, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator and washtub don't turn
sounds like the drive belt remove the front panel and look under the wash tub for a broken belt
Dec 18, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
How to put belt back on whirpool ultra care II washing machine
There's a very good video provided by PartsSelect which shows the process for replacing the drive belt on a Whirlpool Washer. Video link is below. Best of luck!
Greg
Sep 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirpool imperal washer i was told the coupler was broke on it can i get the instructions out to fix it
If you've confirmed you have a broken motor coupling, the following link will give you the steps necessary to replace it:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The motor will not spin..... can i have a diagram of a motor of ultimate care ii washing machine
The typical problems with "the motor will not spin" is a:
1. Lid-switch (very frequent): Will not drain, incomplete cycling, switch ultimately passes power to motor.
2. Belt or coupling (very frequent) - Belt moves when motor spins
3. Timer/control board (rare)
4. Tranmission (rare)
5. Motor (somewhat rare)
How do you know the actual motor is not spinning? Do you mean, the tub not spinning? Do you have a noise as if the motor is spinning?
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills fine but will not spin
the motor coupling is broken. It is a cheap enough part but can be alittle time consuming to replace. it is located directly behind the motor. it is 2 pieces of rubber and i piece of plastic in between the rubber pieces
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care 2 washer will not spin
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
john h
