I was on the beach and got sand into the Lens of my Nikon Coolpix L14. Now, whenever I turn it on, the lens goes out, then retracts and "Lens error" shows up on the display. Any suggestions?
I experienced the lens error message after taken the camera to the beach. Sure enough, there was sand all over the lens mechanism. First, I cleaned the area by blowing air to remove all sand particles (this took me almost a day). In my case, I did not have to remove the lens from the body of the camera. Once clean from dirt, sand or any other foreign object replace the batteries.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Most of these kinds of errors come as a result of some kind of impact, sand or dirt exposure, possible water damage, or some other problem with the lens. There is a possibility that the lens is off track. Try pulling or pushing (not too hard either way) and see if it may be off track and return it to the correct setting. Since it is not working anyway, try the above a few times and then test the camera to work right. I have fixed more than one with similar (off track problems) and they worked good after wards. Worth a try. If nothing works, I suggest to sell it (include all that you have with the sale) on a site such as Ebay as parts, or as is repair. It should bring something like $20.00 to $50.00. The LCD is worth something over $15.00 alone. The other parts of the camera has value to those who repair cameras.
i just fixed the problem. if your error is like mine, than when the lens goes out, hold it so it stays in place. and blow directly on the lense glass thing. than restart the camera and it should work. ok good luck =]
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak. It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition. The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience. The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism. If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy. I have done it, and returned the camera to working condition, but not an easy job.
i have the same problem, but what i do is turn it on then off and then i pull on the lens a little to get it to go in all the way and then i turn it back on and it works
