20 Most Recent Nikon Coolpix Aw100 26292 Blue Hd Gps Waterproof Digital Camera 2gb Kit Questions & Answers
5answers
My nikon coolpix AW100 has a black screen when it turns on
My LCD was black but everything else worked fine. I snacked it against the palm of my hand as recommended and it worked immediately. Wish I had know when I was travelling.
3/4/2023 9:34:44 PM • Nikon Coolpix... • Answered on Mar 04, 2023
Black screen but no display on ther camera
I've managed to fix it, fix it was quite easy .... simply connect the data cable to your PC then format the memory (backup memory contents), turn it on again. repair work
9/2/2014 4:42:08 AM • Nikon Coolpix... • Answered on Sep 02, 2014
Where can I buy a replacement battery cover door for a Nikon Coolpix s7c please?
Hello again There is one repair place that lists 700 different battery doors, but your is listed and out of stock. AliExpress also lists doors and sometimes they end up on eBay. Your best bet is Nikon direct. https://www.google.com/search?q=replacement+battery+cover+door+for+a+Nikon+Coolpix+s7c ..
10/8/2022 11:32:45 PM • Nikon COOLPIX... • Answered on Oct 08, 2022
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
5/2/2022 2:00:32 PM • Nikon COOLPIX... • Answered on May 02, 2022
The yellow light next to the flash icon is blinking?
Battery is broken, replace the Nikon Coolpix 3100 Digital Camera Battery Bar: http://www.2deals.net/Digital-Camera-Battery/Nikon/Nikon-Coolpix-3100.html
3/5/2022 4:13:10 PM • Nikon COOLPIX... • Answered on Mar 05, 2022
Nikon CoolPix B500 when I turn the camera on it tells me to turn camera off and then on again.
contact NIKON perhaps they can repair it we can not
8/3/2021 7:27:05 AM • Nikon COOLPIX... • Answered on Aug 03, 2021
2answers
Just purchased NIKON COOLPIX B500. I put in brand new Sandisk SD memory card And as soon as I shut the battery case the monitor says “this card cannot be used!” What’s up with that?
At the Time the Camera was made , Nikon lists a number of compatible memory cards. Each year both cameras and cards can read and write data faster. Cheap cards today can be read much faster than written. If any camera can take many photos in a short time, a slow cad will not allow the camera to operate as intended.
2/1/2021 1:38:30 AM • Nikon COOLPIX... • Answered on Feb 01, 2021
Single-shot on coolpix P900
I cant understand your question,please explain your problem clearly
1/8/2020 6:47:35 PM • Nikon COOLPIX... • Answered on Jan 08, 2020
The flash on my coolpix 6500 is not working. I pressed ok on the image mode for flash, but it still shows a line through the flash icon.
Some Modes, Like FIREWORK will not allow Flash. Check your MODE
11/6/2019 5:10:11 PM • Nikon COOLPIX... • Answered on Nov 06, 2019
SanDisk 64 GB SD card is too big for my Nikon COOLPIX S62000
Go to Nikon.com and search for your camera and then look for Memory cards that are compatible
10/16/2019 8:18:30 PM • Nikon COOLPIX... • Answered on Oct 16, 2019
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
9/24/2019 1:52:47 PM • Nikon COOLPIX... • Answered on Sep 24, 2019
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
8/24/2019 1:27:47 PM • Nikon COOLPIX... • Answered on Aug 24, 2019
Changing view on playback on Nikon p610
Not sure exactly what the issue is here - could you be more specific please ? Thank you.
2/20/2019 10:19:43 AM • Nikon COOLPIX... • Answered on Feb 20, 2019
Firmware update coopix s5100
I would suggest you go to the Nikon support site and see if there is a version you can download from there.
2/20/2019 10:18:21 AM • Nikon COOLPIX... • Answered on Feb 20, 2019
MY NIKON COOLPIX S 3000 DIGITAL CAMERA WONT DO ANYTHING AT ALL
Hi Here are some suggestions to try and see where the problem may be: 1. Have you tried to charge the battery? We would suggest trying different USB sources (e.g. a USB port on a computer as well as the Nikon supplied AC adapter) 2. Could the battery be dead? If you have tried to charge the battery in the camera via USB then there is a chance the battery is dead and needs replacing. If the camera had not been used for a long time and the battery was stored with little or no charge, the battery may now be un-chargeable. 3. If the camera has been left unused for a long time the internal battery that keeps the time/date may have discharged. You need to be able to set the time/date before the battery can be charged. If you plug the camera into a USB power source and you can see the menu on the LCD then set the date/time. We hope these suggestions help to get the camera back up and running
1/24/2019 9:36:19 AM • Nikon COOLPIX... • Answered on Jan 24, 2019
Nikon Coolpix Aw100 26292 Blue Hd Gps Waterproof Digital Camera 2gb Kit Logo
Popular Tags
4 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
nikon coolpix aw100 black screen when
  • Cameras
