20 Most Recent Nikon COOLPIX L20 Digital Camera Questions & Answers
Nikon Coolpix L20 LCD meltdown
I would take out the batteries. If you can charge them externally then do so. If they charge inside the camera after a few minutes put them back in and charge them. When fully charged disconnect the camera for any cord(s) and turn it on. It may have needed a reboot.
12/2/2017 5:55:31 PM • Nikon COOLPIX... • Answered on Dec 02, 2017
Nikon l20 the screen froze
Take the batteries out of it let it sit for about 5 minutes and then put them back in
10/25/2017 7:48:10 PM • Nikon COOLPIX... • Answered on Oct 25, 2017
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
8/28/2017 2:40:17 PM • Nikon COOLPIX... • Answered on Aug 28, 2017
How do i fix the
Nikon cameras say battery exhausted when they need new batteries, just swap out the old ones and it should be good to go.
1/1/2017 4:29:43 PM • Nikon COOLPIX... • Answered on Jan 01, 2017
Everything works except the screen doesn't show images.
Try pressing the "display" button slowly but repeatedly.
8/2/2016 5:30:27 PM • Nikon COOLPIX... • Answered on Aug 02, 2016
2answers
L20 card is protected. Slide switch is in correct position, put new card in switch in the correct position, same message. Cards work in computer. Removed batteries, hour, and no difference.
The problem may be the card type or size. There are limitations to what the camera can support. Here is a link to a table of supported memory cards (Brand/size/type) that the Coolpix can accmmodate. https://support.nikonusa.com/app/answers/detail/a_id/16341/~/approved-memory-cards---coolpix-l20%2F-l19
7/10/2016 8:16:55 AM • Nikon COOLPIX... • Answered on Jul 10, 2016
Why does my camara tell me that my memory card is write protected
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
7/5/2016 7:21:56 AM • Nikon COOLPIX... • Answered on Jul 05, 2016
I bought a new screen for my coolpix L20 and I cannot get any images , if I hold it at an angle I can see faint icons
You may have not hooked up something correctly. The backlight is not coming on on the screen If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
7/4/2016 8:59:21 PM • Nikon COOLPIX... • Answered on Jul 04, 2016
How do you fix a nikon coolpix l20 troubleshooting with a blank screen when turned on?
Probably dead. Take to local camera ship.
6/2/2016 8:07:24 PM • Nikon COOLPIX... • Answered on Jun 02, 2016
Is there a reset button on the nikon coolpix s5200
Nikon cameras do not have a reset button. Nikon cameras are reset using the Menu selections. Press the Menu button. Scroll to the wrench icon and press the right arrow, find the selection "Reset All" by scrolling down and press the OK button. If you want clarification, this link will take you to your camera's manual where you can look on page 107 in the Reference Section: http://download3.nikonimglib.com/archive1/aYteu00GjpLw00zsmUU460eHgc05/S5200RM_(En)03.pdf
2/14/2015 3:09:17 PM • Nikon COOLPIX... • Answered on Feb 14, 2015
2answers
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
2/14/2015 2:54:42 PM • Nikon COOLPIX... • Answered on Feb 14, 2015
2answers
Changed the battery and wont turn on
clean the battery connectors on your cam. something is blocking up the connection.
2/2/2015 12:50:14 AM • Nikon COOLPIX... • Answered on Feb 02, 2015
2answers
My Nikon coolpix l20 wont
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
2/2/2015 12:47:09 AM • Nikon COOLPIX... • Answered on Feb 02, 2015
Photos do not show
drivers
11/27/2014 8:30:07 AM • Nikon COOLPIX... • Answered on Nov 27, 2014
THE BATTERY DOOR IN A NIKON COOLPIX L24 WONT CLOSE
This is a clear design flaw. There are hundreds of similar incidents. Just try searching for "Coolpix L22 battery door" Nikon refused even to sell me a replacement door, and asked me to send the whole camera to them for evaluation. Dozens of sellers on ebay and ali-express are selling the replacement door, but not Nikon-USA. They do not sell it. So beware when working with Nikon that they do not stand behind their products.
11/25/2014 7:48:58 PM • Nikon COOLPIX... • Answered on Nov 25, 2014
How to transfer photos from my coolpix L20 camera to my computer? Thanks..
There are two easy ways to transfer photos. 1) Connect via a USB cable. The cable came with your camera. If you lost it, you can buy a new one on line or from Nikon. The cable has a small plug that goes to the camera and a large end that plugs into a USB port on your computer. Once the cable is connected, turn on your camera and your computer will recognize your camera's memory card just like it recognizes an external hard drive or other device. If you go to Explorer on a PC or Finder if you have a Mac, you will see it as a device. Open the device and the folder(s) it contains then copy and paste or cut and paste the jpg files from that location to a folder on your hard drive. 2) Transfer your photos directly from your SD memory card to your computer using either your computer's SD card reader or a USB external SD card reader that you can purchase on line for $20 or less. Open the battery compartment door and you will see the end of the SD card. Remove the card from the camera by pushing it in (it is spring loaded) and releasing. It will pop out. Insert the card in your card reader and your computer will recognize the card as if it were a hard drive or similar. Follow the instructions that I gave you for transferring the files above. Both methods can be simplified if you use software such as Nikon's Transfer NX.
10/2/2014 4:25:27 AM • Nikon COOLPIX... • Answered on Oct 02, 2014
Will a 16 gb work in the cool pix camera
Yes. The L20 works with SD and SDHC cards up to 32GB.
9/2/2014 7:26:19 PM • Nikon COOLPIX... • Answered on Sep 02, 2014
Turn off the flash nikon coolpix L22
Page 30 in your camera's manual shows you. Follow this link: http://cdn-10.nikon-cdn.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/L22L21_EN.pdf
8/31/2014 1:50:22 AM • Nikon COOLPIX... • Answered on Aug 31, 2014
Nikon COOLPIX L20 Digital Camera Logo
404 questions posted
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
bought new screen coolpix l20 cannot get
  • Cameras
