20 Most Recent Nikon COOLPIX L810 Questions & Answers
Hi.
I experienced the lens error message after taken the camera to the beach. Sure enough, there was sand all over the lens mechanism. First, I cleaned the area by blowing air to remove all sand particles (this took me almost a day). In my case, I did not have to remove the lens from the body of the camera. Once clean from dirt, sand or any other foreign object replace the batteries.
Nikon COOLPIX... • Answered on Dec 24, 2019
When you view the photo on the camera it is warped AND when you view the photo on a computer?
Nikon COOLPIX... • Answered on Nov 11, 2017
Are you inserting it the right way round ?
Nikon COOLPIX... • Answered on Aug 02, 2017
Check the batteries
Nikon COOLPIX... • Answered on Dec 07, 2016
As long as the orange light is on, the camera is not ready to make a picture. The focus area, should become green, to tell you the camera is in focus. Then you can press the shutter release button complete. Check the settings of the camera, and put it in automatic. When you put it in one of the manual modes pipe P M S or A, the camera will not take a picture when there is not enough lift or something else you did not take in account. If the camera keeps this way, unless you switched to auto, it could be there is something going on. but let me know it auto des not work.
Nikon COOLPIX... • Answered on May 14, 2016
The little write-protect-switch on your sd card is perhaps the problem - that it was shifted by vibration and stands protect instead of free. or that it already was not good set or by slide or re-connect it was moved , if not may be replace the sd memory card.
Nikon COOLPIX... • Answered on Feb 12, 2016
Whether the lens is coming outside or not ? and what is the color of the blinking light ? if its red then Your camera could either have a lens error or other problem. YOu need enough battery source to run your digital camera. Change the battery on your coolpix and let me know.
Nikon COOLPIX... • Answered on Sep 07, 2015
Always be sure the battery is charged and suited for your camera. Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera. Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera. If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery. If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power. Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended. Never use manganese (Zinc-Carbon) batteries in your camera.
Nikon COOLPIX... • Answered on May 10, 2015
Lens chamber might be damaged, Consider replacement of lens gears/assembly.
Nikon COOLPIX... • Answered on Feb 18, 2015
Its and hardware issue, caused by damage to Lens assembly, Visit Nikon service center for the better solution.
is it getting Powered ? or is there any light indications ?
Press the Menu button. Press the tab with the wrench icon. Now press "Reset All" and push the "OK" button.
Nikon COOLPIX... • Answered on Feb 08, 2015
any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
Nikon COOLPIX... • Answered on Jan 15, 2015
not sure, but it sounds bad. you could send it to nikon on L.i, Ny, but they are wicked expensive. Try local repair shop first.
Nikon COOLPIX... • Answered on Jan 09, 2015
It would help to know if the lens extends when you turn on the camera. Assuming it does and that you have made a setting error rather than a functional issue; reset your menu settings. If you do not have a copy of the L810 instruction manual, you can download it for free at http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L810RM_CH(11)03.pdf. Go to page 65 and follow the reset instructions. If you still have the problem, contact Nikon Service at 1-800-645-6687 between 9AM and 8PM EST, Monday through Friday for a repair estimate and instructions.
Nikon COOLPIX... • Answered on Dec 28, 2014
The first thing I would do is check is the battery and charger. The L810 switch will not function if the battery is too low. If the battery is old, it may appear to charge, but not hold the charge. If it is over two years old or if you leave it unused without recharging it for extended periods, I would buy a new one. The charger could also have a problem. If a new battery does not work, replace the charger; it is not expensive. If all else fails, call Nikon Service to arrange repair at 1-800-645-6687 from 9AM to 8PM EST, Monday to Friday.
Nikon COOLPIX... • Answered on Dec 25, 2014
Nikon COOLPIX L810 Logo
146 questions posted
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
camera not recognized pc
  • Cameras
