Moved from one TV to another see light on roku but each input shows no signal using an HDMI cable
SOURCE: Can't get Roku N1100 to
Make sure you select the correct input for your device. If you are using RCA cables then select the RGB option on your inputs, or it may RCA as a connection. If you are using HDMI then make sure that is selected.
SOURCE: How to hook up
You do not need a smart tv in order to use the roku. Basically the roku device makes your TV Smart. The basic connection is just an hdmi cable, and some type of internet connection. Depending on the Roku you have, you can either go with the built in wireless, or you can hard wire the internet. The same type of cable that you would use to hook up a computer to your router.
SOURCE: How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
