Here's the solution from the JVC Customer Service. BE WARNED: this will wipe out all your customizations, including but not limited to favorite addresses and radio station names.
"As for turning off the message about the maps on the radio, please follow the next steps.- Please follow this procedure to perform a factory reset and remove the message. 1. Turn ON the radio 2. Set the Source to "Tuner" mode 3. Simultaneously press and hold the [Disp], [Map] and [Down] buttons for more than 2 seconds - You must press the buttons in that order 4. When the "Service Menu" Screen appears you may release the buttons 5. Touch the UP/DOWN arrows to highlight "Initialize All" 6. Touch [Enter] to initialize the unit 7. The unit will be initialized and the unit will reset on its own. "
first check the volume to be on ..and razed...if this seam not to be the issue ..get into the av menu ..and select sound ..and in there check the out-put ...and select the out-puts in use.. The volume you should select it on the screen and raze it ..not with the remote... If all these seam to be in order..but you have no sound..you should check the speakers wires to be plugged in ok ..and have no damages.. In the end you can make a reset to factory settings ..and default all ..If it does not have it in the menu ...select the initial settings ..when you first open it ..(probably have to be disconnected to display this menu ..) I will link the manual for it here ..and you can check it for any other questions .. http://www.manualnguide.com/dl/21319/
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Connect the parking break as recommended. Then check whether the video appears when parked. If not, send it for service. If yes, then the bipass was not done correctly.
iam having the same problem had power know no power
solution for reset 08 for jvc kw-nx7000
iguoiu
