I don't have a definitive answer but I have an idea you could try. With the power plug removed from the socket, pick the unit up and give it some really good shakes and possibly turn it upside down. I am guessing the unit contains an internal "tip-over" sensor which I'm hoping will become unstick and reset itself. After you've given it a good shake, let it settle for fifteen minutes or more, and restore electricity. If your actions reset the sensor (and you're "lucky"), it should heat up and operate normally. If that doesn't solve it, I fear you're SOL and you may need to toss the unit.
Here is a tip I wrote about how you can bleed the air out of the lines to get the oil burner working again...
How to Bleed Oil Burner - Beckett Oil Burner Repair
heatman101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
problems..
DeLonghi
heatman101
problems..
DeLonghi Space
heatman101
Here is a tip that I wrote
that will help you to understand about oil filled radiator
heaters....
Oil
Filled Radiator Heater Leaking
heatman10
heatman101
heaters....
Oil
heatman101
