Heating & Cooling Logo
Question about Honeywell Heating & Cooling
My Honeywell thermostat has a code E43 showing and I am not able to connect using my mobile connection as in the past. It referred me to my users manual but I can’t find my manual
Posted by bell_m58 on
  • Honeywell Master
  • 6,609 Answers
Honeywell has the manuals for most of their thermostats on their web site. Start here, https://customer.honeywell.com/en-US/Pages/Department.aspx?cat=HonECC%2520Catalog&category=Wi-Fi%2520and%2520wireless%2520models&catpath=1.2.1.4 , for the Smart thermostats.
The E43 error indicates that the thermostat can't communicate with the router. Make sure that the router can communicate with your WAN (wide area network). Check the power and that the Ethernet cable is plugged in and undamaged. Reboot the router (unplug it and wait before plugging in the power cord). If you recently changed the password or the router SSID (the name of the network that the unit uses in its communication), try resetting the internet connection. Similarly, if you have a new router, reset the connection. Make sure that you know the SSID, password and encryption for the router.
I've checked the directions to do this on the Focus Pro TH6320WF series. Press More on the thermostat for 3+ seconds until the screen displays two numbers and the button labels are Done, Back and Next. Press Next until the larger number on the left of the display shows 39. Use the Up/Down arrows to change this to 0. Press Done. Take another Wi-Fi enabled device (tablet, cell phone, laptop) and set it to look for other available networks. Find the network with Thermostat in the name and connect to that network temporarily. If you see a prompt about the type of network, call this a Home Network. Open your web browser and go to the thermostat's Wi-Fi set-up page. (If needed, navigate to http://192.168.1.1 .) Find your router's home network's name in the list of available networks. Press Rescan if the SSID is being broadcast but doesn't appear in the list. If the router does not broadcast the SSID, enter the router name in the text box. Enter the encryption mode for the router. Follow the on-screen directions and press the Connect button. Enter the router password when prompted for the information. Wait to see the Wi-Fi Setup Connection Success in the display. If it doesn't check if the password was correctly entered, including special characters.
I hope this helps. The manual for the Focus Pro thermostat is here: https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2736EFS.pdf .
Posted on Jul 14, 2018
5 Related Answers
fixr1st
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Anonymous
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
Anonymous
SOURCE: Transfer images from mobile to computer
i have Nokia 6630..i want to tranfer images from my mobile to pc through USB but i dont know how to connect it & i dont know how to use it..can you help me with this problems?
Posted on Sep 19, 2008
pierre1811
Perry Putnam
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
Anonymous
SOURCE: GPRS setting required for LG KG200.
Go to http://bsnl.co.in/service/mobile_gprswap.htm
Scroll down & click on CLICK HERE TO DOWNLOAD GPRS/MMS/WAP setting
you will be taken to service portal - here select your state and follow on screen instructions your problem will be solved
good luck
Posted on May 28, 2009
Thermostat recognizes wifi but remains off-line
f your thermostat either displays a no Wi-Fi icon on its screen or shows up as offline on the Lyric or Total Connect Comfort app, it is missing the connection to the Wi-Fi network.
A few preliminary things to check:
  1. Does your thermostat have power? If not, check to make sure your C wire (common wire) is connected to your Honeywell thermostat. All Wi-Fi and connected thermostats (except the Lyric Round model, which can operate using Phantom Power/Power Stealing) requires a C wire to power your thermostat. Regardless of model, if you use Apple HomeKit with the thermostat, a C wire is required. If you are not sure that you have a C wire, please reference our Thermostat Wiring Compatibility page for more information.
  2. Honeywell Wi-Fi thermostats are only compatible on the 2.4 GHz frequency. Newer routers can operate on multiple bands, usually 2.4 GHz and 5.0 GHz. Please check that your router is emitting on the 2.4 GHz frequency.
  3. Check the distance between the thermostat and the router to ensure that the thermostat is in range of a Wi-Fi signal. A simple way to check this is by looking at the Wi-Fi signal range on a mobile device when standing near your thermostat, but note that most mobile devices usually pick up 2.4 GHz & 5.0 GHz Wi-Fi signals. In extreme cases a Wi-Fi range extender or repeater may be needed to ensure you have sufficient 2.4 GHz Wi-Fi coverage throughout your house or business.
  4. Check that your router's firewall doesn't block the thermostat.
In addition, please follow the next steps:
  1. Make sure your Wi-Fi router is powered and broadcasting. Restart your router by pressing the OFF/ON button or by unplugging the device from the socket for approximately 5 seconds and plugging it back in.
  2. If the problem persists, please reset your thermostat. Reference your user manual for instructions on how to reset your thermostat. The manual or quick start guide will have come inside your thermostat's packaging.
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Manual foe a RCH9300WF
It's pretty basic actually. I've done this with Nest and Honeywell Lyric. The only thing you need to do is removing the current thermostat from the wall and connect the new one.
Set it up using your mobile application and you're good to go.
1helpful
The post imade yesterday i was refering to a honeywell central heating room stat NOT a microwave ..dont know how that pic got there.!! how do i reset the dial so its in the correct position ..its working...
It is a thermostat, you are showing here. The thermostat can be defect, when it does not switch on the correct temperature. But when the 3 wires I see are the only ones, connected to the system, I wonder it could work at all.
Is this in the Netherlands?
Changing a honeywell T6060 room thermostat to a T6360B. The current wires are wired as 1 Red 2 has 2 Black and Live has another Red. Which of these wires should be connected where on the T6360B?
Can someone please tell me what a honeywall t6060 for and how to use it cause if it's for the aircon so its warm as well as cool then I'll like to knw as it dosentvwork past 15 and cuts out otherwise it's just cold and hot able thanks
2helpful
2answers
Honeywell T2060 UtilityPro Demand Control Thermostat
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Honeywell t8601d showing a square symbol error - in past this has indicated low refrigerant. Tech came out, said need to replace thermostat, as compressor would not start, but if manually connected wires,...
There is a sensor that shuts the compressor down when the freon (refrigerant) is low. The tech probably "shorted" out this sensor. If the unit went on when he did this, the charge is low.
Top Honeywell Heating & Cooling Experts
Paul Carew
Robert
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
