Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
SOURCE: Frigidaire gallery series dishwasher wont start
the only other thing i know to tell you,without knowing more about this problem,is check the float switch in the tub(its under a tall cover,remove this cover & make sure it is'nt stuck in the up position)otherwise it could be anything from the water inlet solinoid,a bad switch,or even the pc board.hope this helps
SOURCE: our 6 month old frigidaire
My unit has the same problem and it is due to a failure of the control board. The tech that came to look at it tells me that this unit vents from the top of the tub rather than from the front, and he claims that the installation instructions require a 1" gap between the top of the tub and the countertop.
Now I have found no such information in the installation manual that I downloaded, and I am skeptical that a 1" gap could be done, and if it could it wouldn't look to good.
I am going to pull my unit out and see exactly where the vent fan is and what the clearance is. The service tech says they can't replace the control panel until the installation is proper. I am thinking this is at least to some extent a design flaw with this machine. There seem to be a lot of reports of this failure.
SOURCE: my frigidaire gallery series dishwasher wont start
I would cut the power to it for a full 5 minutes and see if it resets itself???????
SOURCE: Frigidaire PLD4375RFC Dishwasher error "ER s" any
error message says ou-what does that mean?
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
