Look on both sides and the front of the computer for the wireless switch to turn it on.
After you turn the switch on there are keystrokes that can also toggle the wireless on or off. Normally you Press and Hold the FN function key located at the lower left portion of your keyboard, then hit the correct (F1 thru F12) key that toggles the wireless. The correct key to hit will have the icon of a wireless signal ))) or it will have the icon of a tower with the wireless signal ))).
The keys along the top ranging from F1 to F12 will have icons on them. you will need to locate the icon that resembles a WiFi tower or radio signal. By default the F1-F12 keys are inverted performing their functions such as turning WiFi on and off so the Fn key will not need to be pressed unless you have changed this setting (typically in the BIOS). If pushing the button with or without the Fn doesn't turn your WiFi on and off then you may be missing the software needed for this to function correctly and you will need to visit Dell to download applications related to your wireless.
to turn on the wireless go to device manager from Computer and go to hardware nad you would find it, try uninstall/install for your wireless adaptor and then try going to network places on left you have my network places then for your wireless network icon make right click and disable/enable.
If this also does not work try installing the driver for the wireles connection again.
There is no physical wireles switch on your laptop. You should however, be able to hold down the "fn" key at bottom left of the keyboard and then hit the F2 key at top left to turn your wireless on or off. If that does not provide the desired effect, then your wireles adapter may be disabled, in which case you should right click on the wireless icon in the bottom right system tray and choose "Repair" or "Enable".
turn on/off, unplug, plug in, should reset configs. go to applications folder for your computer, dbl click printer icon for make of printer/scanner/copy. check settings. if all else fails, select printer reset button in settings page. lastly, go to web site of printer model and check site for trouble shooting if this does not work above. hope this helps and good luck
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should reset printing formats. lastly, go to web site of printer model and check site for trouble shooting if this does not work above. hope this helps and good luck
You want to secure the wireless network. Is there any computer connected to the router with the Ethernet cable? If not then you will need to connect the computer to the router with the cable. Check the IP address on the computer. Open the router set up page. Once you open the set up page, you will find the option to make it secured
in my experince. there is not wireles swich in lapto. it is progrram. and stall inside add or remove progrram . you can get it on *********** board cd.after instiling wecan see in quick lunch bar
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
