Many free software tools are available that can help you to recover your lost data. Following are some of the free important tools:
·RecoverIT
·Stellar data recovery
·Recuva
If your computer has an SD card reader you can get free software to recover the pictures on it. If not then get an external SD card reader and google photo recovery on SD cards.
SOURCE: SanDisk 1GB microSD Memory Card
You can't even format them when they are write-protected. I have the same problem with 2 different SD cards. The lock is in the off position but it still says they're write-protected and can't be formatted either.
SOURCE: my memory card has bad format should i get a new one
If you have a card reader try to format it via your pc that may help to recover your card. Else you have to purchase new one. Best of luck.
SOURCE: i am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
SOURCE: how can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
