20 Most Recent Sony Handycam DCR-TRV530 Digital Camcorder Questions & Answers
GT Recovery for Windows Download: www.gtrecovery.net. Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones. It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks. Key features of Data Recovery - GT Recovery for Android: 1). Preview & selectively retrieve photos and video lost due to any problem 2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Sony Handycam... • Answered on May 20, 2019
you need firewire to import video, unsure of Imovie software, should not matter once on pc
Sony Handycam... • Answered on Apr 07, 2019
Here is the user manual: click here>
Please be sure to rate my answer as a 3 or 4 thumbs up if you found it useful (1 or 2 thumbs-up are like saying "Didn't help or wasn't what I was looking for")
Thanks for using FixYa and Happy New Year!
Sony Handycam... • Answered on Jan 01, 2016
For me, the alcohol sensor cleaning didn't work. I did some research on how the sensor works and it turns out the black stuff is conductive in low humidity and resistive in high humidity. That means the circuit need to be cloed to work,, cleaning off the black substrate would only open the circuit furthur, I cant understand why removing the black substrate is working for some people. After cleaning it to no avail, I tried bypassing (shorting) it. To test it I just took an ordinary pencil and filled in some conductive carbon where the black square was. And it worked. I could have bypassed the sensor by shorting the 2 solder contacts, but to reach it I would have to take it all apart. I'll make the bypass permanent when I have a day free.
Sony Handycam... • Answered on May 29, 2013
Hi, ok now you hold your breath and follow the instructions.. 1. remove all the batteries including the tiny backup battery (usuall seen behind the screen) 2.then hit it very hard.. now insert the batteries and check .. if you dont belive read the link http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html all the best regards sreejith
Sony Handycam... • Answered on Apr 11, 2013
Hello
Try this. Remove the memory stick your camera. If there is a LOCK switch on the back of the Memory Stick Duo, please be sure to set it to the unlocked position before attempting to delete or write data to the stick. If the switch is left in the locked position when attempting to delete or write, the data on the memory stick may be damaged.
Please reply here if you still need assistance.
Sony Handycam... • Answered on Aug 23, 2011
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sony Handycam... • Answered on May 25, 2011
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... • Answered on Mar 07, 2011
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... • Answered on Dec 17, 2010
I found a couple of cleaner tapes for this camera by searching Amazon for "digital-8 tape cleaner".
Sony Handycam... • Answered on Dec 08, 2010
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Sony Handycam... • Answered on Dec 03, 2010
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Sony Handycam... • Answered on Nov 05, 2010
The error code C:32:20 is a take-up reel malfunction. The ejection malfunction is something else and can be caused by several problems including a defective eject switch in the cameras internal circuitry and can usually vbe repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sony Handycam... • Answered on Sep 10, 2010
This code means
"FG fault during normal drum operations. Load the tape again, and perform operations from the beginning."
'C' indicates consumer-fixable problem.
'31' indicates the fix method (remove casette).
The 'FG' signal from the capstan motor is the tachometer signal that the camera uses to monitor the rotation of the capstan.
Sony Handycam... • Answered on Jun 19, 2010
That icon means u have a jammed or bad 8mm tape in the unit its telling u to eject tape.
Sony Handycam... • Answered on May 25, 2010
To remove tape manually from DCR-TRV530 camcorder, you need to take it apart, take out its mechanism, provide DC 5 Volts to loading motor by external power source to unload mechanism so to take out tape inside.
Let me know if you can do that to provide you more technical details.
Thanks.
Sony Handycam... • Answered on Feb 12, 2010
This would be a shutter issue in the lends meaning the camera lens is not picking up light inside the shutter could be stuck closed so I would have a camera shop in your area look at it if I where you.
Thanks and do hope this finds your acceptance please do rate and click the accept button for my efforts today :) Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sony Handycam... • Answered on Jan 05, 2010
Sony Handycam DCR-TRV530 Digital Camcorder Logo
49 questions posted
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
blinking error code c 21 00 remove from
  • Video Cameras
