How do I fix my computer CD writer Drawer to make it open.I banged it with my knee when it was open,I pushed it closed and does not open any longer.Its the HP 583 Pavillian model,not new but works well Othrwise.I use this drawer to make CDs from my dvd's?I need step by step how to open the tower and try to release the inner drawer so it willmove again.I might need a small inner spring,where canI get this as well for this drawer to open and close with tension.
SOURCE: Internal cd writer
yes, you will need to remove and open the rom up and re align the door to gear.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
SOURCE: Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
SOURCE: DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
