2001 Volvo C70 Logo
A
Anonymous Posted on Oct 13, 2014
How do I get the SRS light off
Can it be reset
A
Anonymous
Diagnose the SRS System & find & fix the problem,
it may have
No Resetting,it's a motor vehicle,you have to get that
resetting stuff out of your head & learn your vehicles
technology
How do I reset the front left SRS light in a 2008 Mercedes Benz
The only way to reset a SRS light is to fix the problem that is causing it to come on. Once the problem is fixed and the SRS module acknowledges a complete circuit, the light will go off automatically.
Air bag light on code 32 try too reset srs dont work
The seat is not part of the srs system
Have to diagnose two different problems
You don't reset things on vehicles,you diagnose
failed systems,make the repair & then clear all codes
& data,not resetting anything
Reset srs light after replacing seatbelt
To reset the SRS light on an Acura Integra, pull down the SRS service connector. Unplug this connector so you have access to jump the harness. Start with the ignition OFF. Jump the SRS plug. Turn the ignition ON. The SRS light will come on then off.------------------------------------------------------------------------------
autel maxidas ds708
How to rest srs light
Hi.
If the SRS light is on it means that a problem with the SRS has been detected and an error code has been stored in the relevant computer modules. If there is no fault the SRS light will go off after disconnecting battery terminals for five minutes (make sure you have stereo code if needed). Most of the times the light cannot be reset unless the fault causing the problem is fied (e.g. defective SRS sensor). The best thing to do is a code scanning that will also reset the light, followed with troubleshooting and repair of the problem that is triggering the SRS warning.
Regards.
Ginko
Where is the airbags sensor located on a 1999 grand marquis
SRS sensors are located under hood in engine compartment. They're bright orange/red and are cylindrical in shape. If your SRS lights are on, you need a special reset tool (very expensive tool) to reset. Any good shop including body shops have SRS reset tools and can reset your lights.
2answers
What is the dash light srs, in a honda accord 2002 vtec engine 3.0
The SRS, or supplemental restraint system, on your Hondamag-glass_10x10.gif Accord 2002,
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdveFZn
responsible for deploying the airbag in the event of an accident. If this system is malfunctioning, the airbag may not deploy properly during an accident. However, the system does warn you of a system malfunction. The yellow "SRS" light on the dash will light up, indicating a problem with the system. Once you've fixed the problem, you need to know how to reset the SRS light on your Accord
Read more: How to Reset a Honda Accord SRS Light | eHow.com http://www.ehow.com/how_6403892_reset-honda-accord-srs-light.html#ixzz0tQdgZ0ic
4helpful
E320 reset SRS
Hi, Joe here to help,
Without going to a dealer, you need to get a scan tool to reset the srs light. Go to an Autozone store, They will scan it and reset it free of charge.
ABS SRS BRAKE LIGHTS
I watched a video on resetting the airbag indicator for HONDA civic. It seems a simple thing to do. have a look at the video. It may be helpful.
fr.truveo.com/How-to-Reset-SRS-Airbag-Indicator-Light/id/3118442620 - 85k -
SRS INDICATOR LIGHT
The SRS light refers to your airbags. You can try reseting the light by going to the webpage that I will give you. If it comes back on after you reset it then there is a problem with your SRS system and you will need to have it diagnosed as your airbags will not function when the light is on. Here is the website:
http://www.geocities.com/myintegra96/srs.html
Let me know if you have more questions.
Thanks
4helpful
4answers
My srs light had been on
I have my srs light that just turned on. I have a c320 2002 how do I reset so that the light can come off
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
