You may have the vcr connected via a video cable from vcr av out to tv av in. If this is the case you should have an rca type audio out on the VCR and a audio in on the TV the plugs are Red and White color coded. THe video is usually yellow color coded. You may have an rf out on the vcr you need a tv cable from this to the TV antenna in port
if using this connection with a video cable instead of a 75 Ohm tv cable. the impedance is different and this could be another cause of your problem. The cables look identical but are different electrically.
SOURCE: VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
SOURCE: Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
SOURCE: LG V8824w DVD/VCR no video
rtfm.
Once the setting for progressive scan output is entered,
an image will only be visible on a progressive scan
compatible TV or monitor. If you set Progressive Scan
to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc
tray. See that "NO DISC" is displayed on the display
window.
2) Press STOP and hold it for five seconds before
releasing it. The video output will be restored to the
standard setting and a picture will once again be visi-
ble on a conventional analog TV or monitor.
SOURCE: VCR has sound but no picture
Your video head are dirty
Needs cleaning
> use denatured alcohol and shamos sticks
> clean tape guides also / they will have residue that will transfer to the video heads.
> be careful not to snag the heads.<<< very delicate
> professional should do the cleaning
hope this helps.
