Mitsubishi WD-65733 65" HDTV Logo
j
joshua j walter Posted on Sep 23, 2014
When i hit the power button, i have sound for a minute but no picture...during the attempt to get picture I can hear a sounds that increases in pitch and then decreases in pitch (sorta like a fire tru
When i hit the power button, i have sound for a minute but no picture...during the attempt to get picture I can hear a sounds that increases in pitch and then decreases in pitch (sorta like a fire truck but a lot quieter.) It does that three times before the tv shuts off and gives me a red light. do i need to replace the bulb? I tried checking the Mitsubishi troubleshooting pages but they no longer exist. :( Can you help?
Lonnie Miller
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 17 Answers
  • Posted on Oct 13, 2014
Lonnie Miller
Contributor
Level 1:
Night Owl:
Answers
17
Questions
Helped
2952
Points
27
Sounds like a bad color wheel
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jun 16, 2006
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Anonymous
  • 3130 Answers
  • Posted on Jul 08, 2007
SOURCE: 42" Mitsubishi 52525
You may have bad capacitors in the DM board.
Anonymous
  • 4402 Answers
  • Posted on Dec 10, 2007
SOURCE: Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Anonymous
  • 3130 Answers
  • Posted on Aug 16, 2008
SOURCE: TV Won't Stay On...
fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
Anonymous
  • Posted on May 15, 2009
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Apex gt 2715 turns on but no picture or sound
Its main digital board should be suspected. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
I have a Toshiba 47hl167 and when I plug it in and hit the power button the green light comes on but no picture?
The real issue is do you have sound or not?
You can unplug the set and or a box both if connected for several minutes and then power back to see if when they reboot set works or not.
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
1helpful
I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
