Question about Apex Digital Televison & Video
Apex gt 2715 turns on but no picture or sound
When you power the tv on you can hear it come on, but there is no picture or sound and when you hit any channel button (numbers or up/down) the tv shuts off by itself
    Top Expert:
  • Apex Digital Master
  • 76,204 Answers
Its main digital board should be suspected. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Posted on Mar 13, 2013
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
Anonymous
  • 36 Answers
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Posted on Jan 09, 2008
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Posted on Jul 08, 2008
Anonymous
  • 252 Answers
SOURCE: I get sound but no picture on my apex at2402.
if there's a channel and volume display but no picture,the problem of your tv is ABL..it is a resistor value from 10K ohms up
Posted on Oct 11, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: How to unlock my Apex TV #at2002 with only KEY shown in the corne
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels..
Please rate this Fixya solution
Posted on Jan 20, 2009
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
Power light is on but nothing comes on,when i hit the channel button i get sound for a second but no picture
what is your brand name and Model number to TV it will be on back of TV.Thank You.
Jan 06, 2010 | Televison & Video
NO Picture or Sound
sounds like someone rolled over on the remote. if you have cable or a dish, the tv channel must be left on a specific station at all times. no matter what channel is on the cable, the television itself must be on the correct channel number in order to receive he signal from the cable company. try hitting the last channel recall button on the tv, not the cable. otherwise try channel 3 or 4 or sometimes 60 on the tv. good luck
Nov 11, 2009 | Televison & Video
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
Picture is a little fuzzy and does not fit the screen
Good Day, mopar69;
Try this and if does not work, call SONY TV with Model and Serial NUMBERS, this sounds like you may have a defective light engine, and they are having problems with them, and they , Sony, are covering that device.
Restoring unit to Factory Preset Condition
1) Power off the set (set is now in Standby Mode).
2) On the remote, Press DISPLAY, CHANNEL 5, VOL +, POWER.
3) On the Remote press CHANNEL 8, ENTER.
4) Wait until Initial Setup is displayed.
5) Turn off TV sets power by the Remote or Front Panel button.
6) WAIT AT LEAST 3 MINUTES UNTIL THE LAMP COOLS DOWNS BEFORE UNPLUGGING OR DISCONNECTING THE AC FROM THE TV. If the set is not allowed to cool down the lamp may be damaged by excess heat build up.
I hope this was helpful, Good Luck, big IRISH.
Aug 05, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
RCA 27F520T no picture problem
 Examine PCB closely,probable cracked board.Depending on
how severe,it may be fixable.Ask repairman what the bench labor
charge will be to repair,if repairable at all.
Oct 11, 2007 | RCA TruFlat 27F520T 27" TV
No picture but there was a sound
1.service mode before putting unit into the service mode, check that customer adjustments are in the normal mode. use the reset function in the video adjust menu to ensure customer controls are in thier proper(reset)position. 2.service number selection once in the service mode, press the channel up or channel down button on the remote transmitter or at the set . the service adjustment number will vary in increments of one,from "S01"~"S19" to "M05". select the item you wish to adjust. 3.data number selection press the volume up or down button to adjust the data number. to enter the service mode. while pressing the vol-up and ch-up buttons at once, plug the ac cord into the wall socket and switch on the main power. now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Sep 19, 2007 | Sharp 27J-S100 TV
Televison & Video Logo
107 people viewed this question
Top Apex Digital Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
