Replace blade instructions
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
SOURCE: Milwaukee 6390 dead
I dont know how old the tool is but when I worked on them it was notorious for exploding the commutator and damaging the brush holders, hopefully yours didn't do that. You have voltage at both brush holder then I would remove the brushes (UNPLUG TOOL FIRST) making sure they are not sticking in the tubes and while they are out rotate the tool by hand and look for any noticable difference in the commutator bars. Check all the connections from the field to make sure the circuit is complete like it sounds that you have done and if so that just leaves the two items I mentioned. Let me know if I can help further.
SOURCE: I have a 7 1/4 milwaukee circular saw.It won't
Could be quite a few, what is the model number. Do you have a volt ohms meter, if so check the cord first (UNPLUG) and across the switch then lock the switch on and check the brush holder leads. If you loose continuity anywhere in this process that is probably the problem. What did the brushes look like, did the mating surface look smooth or burnt. Let me know and I will try and help also give me the model number and brand, the header has 2 listed.
SOURCE: B&D Corded Circular Saw - Arbor Does Not Move
This model is not equipped with a clutch so its possible that the gears are stripped, shaft broken. If the blade moves freely then this is probably the case. If blade does not move freely, check for any foreign objects between blade and blade housing. I hope this has helped if you have any further questions don't hesitate to ask. Please rate on the helpfulness of the answer. Good Luck and have a great weekend.
Testimonial: "Thank you for your prompt response. My B&D Circ Saw Model is 7301-Type2. I will try your recommendation. Will keep you posted. Thanks again."
SOURCE: Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
