20 Most Recent Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Questions & Answers
The motor capacitor is dead. Replace it and it'll be right as rain!
Regards, --W/D--
Sears Craftsman... | Answered on Feb 19, 2018
worn or damaged bearing --brushes worn --
Sears Craftsman... | Answered on Jul 25, 2017
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Sears Craftsman... | Answered on Oct 16, 2016
quite possibly there is none . most people use a block of wood held against the blade.
Sears Craftsman... | Answered on Mar 26, 2016
broken contact powercable , switch but measure to carbonbrushes to each other with signal measure multimeter , the autostop in the carbonbrush can be activated. or 1 of the 4 wires on the electricfield is broken
Sears Craftsman... | Answered on Feb 25, 2016
remove the power lead from the wall socket
put a screw driver in the teeth of the blade and use it as a stop against the guide
use the right size spanner and undo the blade retainer nut
Sears Craftsman... | Answered on Sep 06, 2015
Close match to 315.108220 Craftsman Circular Saw Owners Manual is the 315.108241 PDF manual
The 315.108241 manual is available for free download at:
http://www.hammerwall.com/Manuals/Craftsman/Description/315.108241/Craftsman%207%2014%20in.%20Corded%20Circular%20Saw/L0807084/
Sears Craftsman... | Answered on Jun 19, 2015
Always away from you.
Sears Craftsman... | Answered on Jul 18, 2014
Release the base plate lock so the saw will sink into the well at the bottom of the case.
Sears Craftsman... | Answered on Sep 05, 2013
Is this a brushless motor?
Sears Craftsman... | Answered on May 21, 2013
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Sears Craftsman... | Answered on May 07, 2013
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
77 questions posted
Top Sears Saws Experts
efs_perpends
efs_perpends
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
View Most Popular
Sears Saws
  • Sears Saws
Most Popular Question
craftsman radial saw runs hums but wont
  • Saws
