All wires were rotton and dont know were they go now need help its a inline 6 outbaord 115hp mercury
SOURCE: dont know wich wires go to wich prongs on ignition
You can get a wiring diagram by going to a web site for OMC Motors
Jim OMC Retired Mech
SOURCE: I want to disassemble the lower unit on the 115hp
you actually want gear housing exploded view and/or lower unit mid section exploded veiw-i have the mercury service manual for the inline series 75 thru to 150 2 strokes-but my printer/scanner down at moment -hopefully fixed this week so will be able to scan and send to you
SOURCE: How do I winterize my Mercury 115hp outboard motor
add Stabil to the gas tank and run the engine for a few minutes so it gets into the carb. Then pull the plugs and spray fogging oil into each cylinder and then turn the engine over a few times. If you are in a cold climate you should drain the lower unit in case there is water in it and then refill it with new lower unit grease. reinstall the plugs and you will be ready for winter.
SOURCE: boat ran great for 5-6 outings and all of a sudden
check the fuel filter ...or you high speed jets are clogged
