20 Most Recent
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Questions & Answers
HESITATION UPON ACCELERATION
Try fresh fuel...if carberated then clean out carbs. Sounds like clogged jets from varnished carb bowl and old fuel.
Verado will not trim up once out of the hole gets
You need to check your power trim resevoir to see if it is full. Also check trim ram seals to see if they are worn. When there's bad seals, water penetrates the ram and will prevent the rams from extending to their full potentential under power.
We have a mercury 60 2stroke outboard engine and
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
35 hp merc
fuel pump reed valves bad gas tank or hose
