20 Most Recent Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Questions & Answers
Adampeake how do you download free from the web link
they wanted $19.99USD
Clymer... | Answered on Apr 20, 2019
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Clymer... | Answered on Dec 13, 2014
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Clymer Boating | Answered on Oct 04, 2017
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump...
Also have a look at your spark plugs...
Clymer Boating | Answered on Sep 25, 2017
clean carbs and check set up !
Clymer Boating | Answered on Jun 04, 2014
Only three ways
Connect a transducer or head unit from a friend.
Buy a new one.
Return it to the factory for testing.
Does your mystery fish finder have a demo mode? That _should_ prove if the head unit is olay.
Boating | Answered 10 hours ago
Not sure if this link will help
https://www.bitchute.com/playlist/zdU7Ihae6i4C/
A little history on the glastex later sold as sea star and sea spirit
http://www.fiberglassics.com/library/index.php?title=Sea_Sprite
Boating | Answered on Jul 06, 2020
CHECK WITH THE MANUFACTURER IS ALL i can suggest as a fix NOT SOMETHING A DIYER HAS THE CAPACITIES TO DO
Boating | Answered on Jun 25, 2020
Hey Bill, NADA does not list a 2605 for 2009..
is this an outboard or stern drive..
2009: 2301 WA STRIPER 24' STERN FG 1 220 4450 8'6" Gasoline 2301 WA STRIPER(**) 24' OUTBD FG 1 200 3850 8'6" Gasoline 2601 CC STRIPER(**) 26' OUTBD FG 2 150 4250 8'6" Gasoline 2601 WA STRIPER 26' STERN FG 1 270 5150 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 2 150 4550 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 1 225 4550 8'6" Gasoline 2009 Seaswirl Boats Prices Values
Boating | Answered on Apr 21, 2020
GOOGLE IT WITH THE MAKE STATED FIRST
This one?
https://www.walmart.com/ip/Electronics-Built-In-Bluetooth-Marine-Antenna-Cone-USB-DIN-Speakers-Stereo-LCD-Range-Two-Port-WCP365BT-Single-Long-inch-Dual-6-5/658806335
RT is normally reserved for transmitting, this is a receiver. Or is it linked to a two way transceiver and automatically cuts out music for telegraphy transmissions coming in?
I can't find the manual for it. The reviews at the lower part of the page suggest it is a bargain basement unit. I have a Jenson :>)
Boating | Answered on Apr 11, 2020
Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Logo
4 questions posted
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
115 johnson moor spits sputters when
  • Boating
