What should I do? I already cleaned it all out. It seems that no matter what setting it is on there is not a lot of cool air that is blowing out of my air condition the room is always like 80 degrees in there,
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
SOURCE: air comes but not very cool
If your house is not getting cold enough when your room A/C is turned on, It is time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Portable_Room_Air_Conditioners_Window_Air_Condit_No_Cool_Air.htm
Read the article, and, if need be, take advantage of the link for free four (4) quotes and "pick the brain"--seek the advice--of these technicians who offer you a free quote to discern what could be the problem.
SOURCE: blowing out warm air
This could be a refrigerant leak. Before you call out a service technician, clean the filters and then try to see if it works. If it doesn't then get the unit serviced.
Hope this helps
I take the time to answer your questions, so please rate me.
Mat
SOURCE: blowing out warm air when i put in cooling mode
is the compressor running? usually a louder noise? may be low on refrigerent....need guages to assess
SOURCE: My electrolux split-type room air conditioner will
theres usualy 2 things that could be faulty there its either a faulty sesor or the four way exchange valve solanoid is faulty
