20 Most Recent Frigidaire 6500-BTU Window Room Air Conditioner ENERGY STAR LRA074AT7 Questions & Answers
How can I remove the front cover?
you cant
8/17/2014 12:48:38 PM • Frigidaire... • Answered on Aug 17, 2014
Ac unit keeps tripping the reset button
Good Afternoon Friend, I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/23/2014 8:23:31 PM • Frigidaire... • Answered on Jun 23, 2014
Unit acts like a ghost has taken over the
Sometimes the button boards will get worn or malfunction. Nearby lightning strikes make electronics flaky sometimes. But start with the button board. www.searspartsdirect.com
9/27/2013 1:50:32 AM • Frigidaire... • Answered on Sep 27, 2013
Window ac/heater freezes up when using the heater?
This is likely due to a lack of airflow. Make sure that the air filter is clean and that there are no obstructions blocking the air intake or exhaust vents. If this does not resolve the issue, you may need to have a technician come out and inspect the unit for any other potential issues.
2/14/2023 12:17:18 AM • Frigidaire... • Answered on Feb 14, 2023
Frigidaire model fftr1835vs styrofoam inside filter housing unit. Should it be there?
Not 100%certain to what styrofoam you are referring to but there is definitely styrofoam components inside the machine. The entire drain pan is made of styrofoam, I would not touch it.
7/4/2022 9:22:49 PM • Frigidaire... • Answered on Jul 04, 2022
New Frigidaire Portable ac unit turning off and flashing 8.8
Have you drained the water?
7/2/2022 7:30:52 PM • Frigidaire... • Answered on Jul 02, 2022
2answers
The "filter reset" button keeps turning on on my
The blower wheel probably is dirty. The unit is sensing that not enough air is flowing across the AC coil.
6/27/2022 12:31:44 AM • Frigidaire... • Answered on Jun 27, 2022
2answers
The compressor on my Fas257r2a 25000 btu stops running before the room is cool. but takes awhile before compressor starts up again What could be the problem?
Mine is doing the same but it's very moldy and dirty. It worked well when we used it for the first month when we moved into our Gma's house. She left the unit. It's old yes but it worked fine before. Why is this happening? I'm going to clean it, but I have NO IDEA HOW TO GET IT OUT OF ITS CASE! HELP
6/20/2022 12:59:27 PM • Frigidaire... • Answered on Jun 20, 2022
My Frigidaire 12,000 BTU window air conditioner is tripping as soon as I plug it in!
did you clean it with water? They don't mix. Use a hairdryer to dry thoroughly.
6/18/2022 6:59:05 PM • Frigidaire... • Answered on Jun 18, 2022
I have a Frigidaire FGH2272UF and want to change from centigrade to fahrenheit? Help
Here are some videos, but it looks by doing a search on that model, that you can't change it. Having said that, the manual shows both, but perhaps that is for display. https://www.manualslib.com/manual/1581184/Frigidaire-Fg4h2272uf.html?page=13#manual Videos https://www.google.com/search?q=Frigidaire+FGH2272UF+change+from+centigrade+to+fahrenheit This search forces your model to be featured https://www.google.com/search?q=Frigidaire+%22FGH2272UF%22+change+from+centigrade+to+fahrenheit It doesn't appear to be in the manual. Centigrade is much easier. Fridge at 3'C and Freezer at minus 18'C. Freezing is 0' and boiling is 100'. You can hang an American thermometer inside. https://www.manualslib.com/manual/1581184/Frigidaire-Fg4h2272uf.html .. ..
4/13/2022 6:15:05 PM • Frigidaire... • Answered on Apr 13, 2022
2answers
Can't change temperature on AC
thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
6/30/2021 4:29:10 PM • Frigidaire... • Answered on Jun 30, 2021
2answers
Why does my wall unit Frigidaire air conditioning fuse keep blowing when I it's on the power cord
probalbe causes may include loose connection, voltage drop (undersized circuit conductors), wrong type of fuse, bad compressor, motor or capacitor,
12/23/2020 5:59:09 AM • Frigidaire... • Answered on Dec 23, 2020
2answers
I have a kt-9018e universal a/c remote can you tell me the code for a frigidaire
Thank you for your post, John!
Based off the information you have provided you need the code for a universal air conditioner remote. You may need to speak with manufacturer of the remote for that direct code. Best of luck! -Matt
6/11/2020 6:32:20 PM • Frigidaire... • Answered on Jun 11, 2020
After 11 years, my Frigidaire window unit has stopped blowing cold air. On the first startup 3 days ago, it blew cold air after 5 min. Then 2 days ago it blew cold air after 10 min. Today no cold air.
Make sure that the cooling coils are clean. Also that the cooling fans are working. It may have lost it's treon and it is time to buy a new one.
5/20/2020 2:44:21 AM • Frigidaire... • Answered on May 20, 2020
Frigidaire 6500-BTU Window Room Air Conditioner ENERGY STAR LRA074AT7 Logo
4 questions posted
Top Frigidaire Heating & Cooling Experts
Robert
David Shaub
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
remove front cover
  • Heating & Cooling
