We just purchased a surround sound theatre system. Works fine for hours, then just switches off. Turn it back on via remote and it works fine for another few hours. Any ideas, or simply a fault??
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
SOURCE: surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
SOURCE: SONY DAVHDZ278 BRAVIA HOME THEATRE SYSTEM SURROUND SOUND PROBLEMS
OK, it is called Cold Reset
Turn unit ON and press following 3 button on same time..
STOP - EJECT - POWER
Display will show Cold Reset briefly and DAV-HDZ278 is reset to default settings.
Thanks.
