SOURCE: Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
SOURCE: Universal Remote Control CODE
You would need to contact the company that makes the remote and maybe Cyberhome for the code.
SOURCE: Lithium Battery Replace
CR2025 is the battery type. I bought mine at Wal-Mart. I am sure you can get them anywhere.
SOURCE: Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
SOURCE: Remote Codes
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
