I would have to assume that a "Seagate external memory" is actually a Hard Drive. If so then you need to note what sort of Port or interface connection it is using. USB / Firewire or a direct connection cable of some sort. Note also the size (capacity) of the drive. You have probably loaded it up so full that it can't function.
The ideal situation would be to connect this drive to a computer and try and recover your files. You need to know what the drive was formatted for. Check the manual. Was it Fat32, NTFS, Mac OS Extended (Journaled) etc or some proprietary receiver format.
Does the dish receiver have the format (erase) utility on board. If the PC or Mac can see the drive on a USB port then you may be able to recover your movies.
If not... You can always format the drive or completely erase all data and set it up for use again. Or you can replace the drive with any number of different brands of drive, maybe even with larger capacity.
Most drives all use ATA or the newer SATA type connector internally. They are all interchangeable. So WD (WesternDigital) Hitachi, Seagate, etc will all work the same way. (All of them have to be able to plug in to different brands of computers. Mac or PC.
Without further info, it's hard to suggest anything else.
Good Luck
Trevor
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
SOURCE: Transfer from Laptop to 250gb WD
you need to format the dirve to NTFS or FAT32
current format has a file size limit
thanks for rating
SOURCE: Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
SOURCE: Accidentally disconnected external HD while moving files
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
SOURCE: How can I recover my files after I drop my external hard drive?
You can recover lost files from dead or formatted external hard drive, visit this guide
Recover files from external hard drive
good luck!
