Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
I lost 60 hrs. of recording time in less than 24 hrs. on VIP 622
I had approximately 110 events loaded onto my Dish Network DVR HD VIP 622 with approximqatley 60 hrs of remaining time. I turned on the DVR this morning and I was down to 83 events and 4 hrs. left of recording time, As far as I can tell no existing events were deleted (I could be mistaken). The majority of movies on my DVR HD are protected as I haven't offloaded them on to my DVD burner yet. I also have a Seagate 500 GB freeagent pro HD attached to the USB port on the back and it has given me no problems, and it almost full of movies.I called Dish Network and they offered no solutions except a reset of my DVR (unplug for 15 seconds and then plug back in). The same data came back up. Apparently there is no second level service at Dish Network any more to help you solve problems.I have received no DVR HD problem messages on screen. Pleae help, thanks. Steve
Posted by 1berens on
  • 1berens Mar 16, 2009
    The solution I got wass to unplug and turn off my external HD and then re-attach it and turn it back on. I am afraid if I unplug and shut off and then re-attach my external HD to the DVR the external HD will reformat, thereby resulting in the loss of all the movies I have recorded on my external HD. I seem to remember that I could re=attach my external HD 1 or 2 times before it would erase the external HD, but I don't trust my memory
Rylee Smith
  • 8,619 Answers
Hi
Connect this external hard disk with your computer and try and search for the deleted content, if you are unable to find the data then backup the data it have. And after data backup format this hard disk and restore the data back to it.
This will resolve ypur problem.
Please ask for any clarifications.
Thanks
Rylee
Posted on Mar 16, 2009
Arjun Komath
  • 1,170 Answers
Remove all the External Storage devices, make sure that you Un-Plug them Completely including their Power. After Resting the Dish Receiver, Plug-In everything back on and try.
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: [email protected] with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Dec 14, 2013 | DISH Network ViP 922
Is this resiver HD ?
am_witek,
Our 625 receiver is not an HD model. Our current HD models are ViP 211/211k, 222, 612, 622, 722/722k, 922, and our Hopper receiver.
If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Nov 24, 2012 | DISH Network DVR-625 DTV Receiver /...
My dish DVR HD control doesn't work
lumaes200,
You have indicated that you have a 622 DVR receiver, since this is where your posting was found. When you trying any of the DVR functions on the remote, do you get an error message (024 or 311) indicating that the function is not available at this time? If not, try unplugging the receiver for 10 seconds from the electrical outlet. This will reboot the receiver and re-acquire the satellite signal. Once the picture returns, try the DVR function. If the problem continues, please call 1-800-333-3474; we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Apr 02, 2010 | DISH Network ViP622 DVR DTV Receiver /...
CANT GET ON LINE
The ethernet port is not active on these receivers thus not allowing you to get on ine. There currently are no plans to activate this in the future but you may for an upgrade to a 722 which does allow this and is HD capable and has 300 hours of SD record tine available. Thanks for using Fix Ya.
Feb 14, 2010 | DISH Network DVR-625 DTV Receiver /...
If I don't have a cable or satellite television service how to install a VIP 622 DVR HD Antenna
Mount the dish on a pole or house using a mast perfectly plumb. Ensure it will give you an unobstructed view of the sky based on the information that should have come with the dish regarding your zip code for skew, elevation and azimuth settings. You will now need to run one line from the LNB on the end of the skew arm to your 622. Remember to use a seperater inside or you will need to run another line into the back of the receiver. Run a hardwire off back of the receiver's home distribution port to . Connect a line from 3-4 on back of the receiver to your TV 1. ....More to come if needed drop me another line.
Jim
Feb 13, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Timers & recorded events erased
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network DVR-625 DTV Receiver /...
I want to record to a external hard drive in order to take to Ira
If you have a dish network system as listed in post a DVR 625 this is NOT possible, it will only work with VIP series Dish Network recivers. and they must be used on teh same model reciever such as Vip 722, tranfer to EXT HD then Watch on another 722!
Jun 18, 2009 | DISH Network DVR-625 DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
335 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
