I replaced thermistor in frig; still warms. If I unplug, it chills, then warms up again.
The problem is most likely to be the defrost heater Check the back of the freezer compartment for frost If you have frost on the back wall of the freezer compartment you will need to unplug the unit and remove everything from.it next get several towels to place on the bottom of the freezer to catch the water from the melting frost Using a hairdryer heat the frosted area to defrost remove the back panel of the freezer under it you will see a frosted up mess after defrosting you will see one or 2 heaters mounted on metal brackets they unplug and can be tested using a ohmmeter or continuity tester also check the defrost thermostat an replace defective items.put it together you should be all set
SOURCE: GE PRofile Arctica
Got mine fixed!
http://www.fixya.com/support/t867206-ge_profile_pts25lbmarww_power_but_no
SOURCE: GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
SOURCE: Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
