SOURCE: Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
SOURCE: Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
SOURCE: Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
