I need tv code to program my shaw direct remote with emerson tv.
0271,0277,0275.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: dynex tv code
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
SOURCE: TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
