Water in the drain pan is not evaporaring. It is filling up and overflowing. How do I fix this?
SOURCE: Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
SOURCE: drip pan overflow
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
SOURCE: water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
