In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
please see the link below it is very detailed (i could have copied and pasted it and made it my own but that wouldnt be right), the video is also very good
i dont think it has..you can then buy a VGA to RCA for the regulatr TV(should work for both the TVs)
an example is here http://www.cablesnmor.com/vga-rca-cable.html
please info if u want more help,will be glad..regards
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
