Help me please i really need these clippers!! for school please get back to me a.s.a.p.
A. If blade teeth are broken or damaged you might find teeth plate repacement. B. If teeth are not damaged, check adjustment screws.C. If you have used it for a long time,it is not sharp anymore and there is not a reliable way to sharpen the teeth realy and you need to replace the teeth plate. But keep in might parts are not cheap and you might be better off buying a new one.
If the clippers stopped cutting, they are probably clogged with hair on the inside of the clippers. I had two pairs of clippers where this happened. I took them to be serviced at a beauty supply store and they cleaned the hair from the inside of both pairs of clippers for me and they now work just fine.
If your blades are not broken and the motor runs when you, also try putting some oil on the blades
Add a CommentIf your blades are not broken and the motor runs when you turn the clippers on, just try putting a few drops of oil on the blades. If the motor runs, the oil will cause the blades to move normally.
Hi Ruben Sifuentes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
