They worked at one time, then slowly stopped working so that now I get the beep, but the voice that used to come on prompting me to say who I want to call does not come on. I have to dial through my telephone.
You can try to press and hold the Call button while turning on
the headset to turn these features on/off and select reset to factory default and just follow the voice prompts to make changes to
these settings. Remember that this action erases all pairing information stored in your headset so you will have to paired again.
SOURCE: No voice dialing
hi when you press and hold the button you redial the last call, and when you press just once quickly this button your phone pass in voice call( if your phone has this function...lol) and don't forget to activate the function voice call in your cell phone.
hope this helps you
sserpentio
SOURCE: voice commands
The telephone has this feature?
This feature is active?
As you sad it's appear that you use that in another telephone, try to check that.
SOURCE: Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
SOURCE: HF850 pairs with my Ericsson TM506 phone, but can't voice dial
The TM506 (also known as Bella) must support the Bluetooth Handsfree 0.96 profiling.
The HF850 supports Bluetooth Headshet v1.1, v1.2 and Handsfree 0.96 protocol.
Unless you can find otherwise, the TM506 doesn't support Bluetooth 0.96 Profiles. It is my understanding that on the TM506 you must program your voice commands and I understand that to be different.
Nonetheless, the TM506 works very well and seamlessly (other than voice dialing) with the HF850.
