Don't know where NZTech was or the post but you need to press the CLK# button on the cash register(third key from left on cash register keyboard at top menu, Receipt on/off then CLK# ) and sign in the clerk.
if you have no clerks setup you may have to set up clerk
check user manual https://manualzz.com/doc/3075262/casio-te-2400-user-s-manual
click on download pdf right hand side of screen
page 86 programming clerk
Try your local community college data processing department. They can probably tell you where to get the software. You might also try some business based web groupds for an answer. Or you could look on eBay for a working replacement which may cheaper and quicker than the other option.
I've run the cash register and then appeared on the screen error e004 ,i am repair the error , and then appeared on the screen error e008, and now I do not know what to do , also i dont know the clerk number please help me
Ok.
I need to know these things:
1. which country is it being used in?
2. Do you want a PIN number to log staff on, or just simple log on?
3. Do you have a row of buttons next to the key called CLERK or CASHIER?
4. Will you be using a bar code scanner?
If anyone needs a Casio TE-2200, TE-2400 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
visit to the given link and download the manual and refer to page no. 114 for E004 meaning and solution...
www.merlinofficeequipment.co.uk/.../Casio_TE-4000_4500_User_Manual.pdf
Hope this has helped you...
Please rate the answer..
Thanks..
Hi. This is very serious. It means the register is about to completely clear everything (or may have done so already). If it has been sitting for a long time without power, or new out of the box, then this is normal. We can try to jump it back out of the init mode.
Follow these steps very carefully:
Turn the power off at the wall. Turn the key to PROGRAM mode. Hold RECEIPT FEED button down. Turn power on at wall. When you see the display change to 'FFFFFFFFFF' let go of RECEIPT FEED. Press SUBTOTAL
Turn the key back to REG mode and try it. If you get error 8, then you may need to log a clerk back on.
