Have you tried taking the battery out? That solves a lot of problems.
SOURCE: Can't find temporary recovery log
the only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
