Question about Tablets & eReaders
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
Gary Tiedeman
    Master:
  • 333 Answers
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
Posted on Jun 10, 2016
5 Related Answers
markdavidoff
Mark Davidoff
  • 20 Answers
SOURCE: My trio stealth 8 keeps resetting it self to
Try doing a factory reset. It can be done from the setting menu usually, or via a special button combination. Google will help you if you google your model number and 'factory reset'
Posted on Sep 16, 2014
atomic0442362
Alan Mars
  • 29 Answers
SOURCE: My trio stealth- 8 powers on but won't boot up and
One of the common solutions from YouTube videos short of more drastic measures would be to hold the power button for 10 seconds.
The below videos may help or will if you must resort to a hard reset - that will wipe all files and restore to original.
3 RESET WAYS on ANDROID TABLETS REVIEW 2nd n/a (pattern lock) Android Tablet stuck on boot screen Bypass it in easy steps Android tablet stuck on Android Logo Fix
Posted on Dec 29, 2014
mike0862
Mikey
  • 6520 Answers
SOURCE: How do I reset my trio stealth tablet. I holded
With tablet off, Hold power and volume+ buttons together until reset page comes on, then select factory reset!
Posted on Jan 04, 2015
mike0862
Mikey
  • 6520 Answers
SOURCE: Hi guys I have a really big problem so my trio
Turn off first then factory reset!
cwradio73
  • 1162 Answers
SOURCE: i have a trio stealth tablet and i locked myself out by fogetting the password, ive tried to factory reset it by holding down power button and volune up buttkn till boot menu comes up but it never get
Restart the device and power it on while holding the power button and volume down until the boot screen clears, keep holding the volume down key as this will allow you to get to the root settings and wipe/cache partion resets and delete user install data. :-)
Posted on Jan 29, 2015
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
Mar 13, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
For got my password and username
unless you have something on it you don't want to lose do a factory reset on it.
Oct 16, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
How do you reset a trio stealth pro tablet after being locked out?
I have a trio stealth pro tablet and I'm lock out how do I get back in
Jan 10, 2013 | Tablets & eReaders
Tablets & eReaders Logo
1,456 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
